Good Morning,
Getting this issue when trying to hide/unhide Exchange Online Mailboxes from the GAL using the Exchange section:
These accounts/mailboxes are anchored on prem with AAD Sync. AAD Sync is working normally and if I modify the AD Attribute directly it sync's and works, the issue only arises when trying to uncheck the "Hide from Exchange Lists" section of exchange which was working previously.
by (350 points)
Unfortunately, this is currently a known issue, but there is no workaround in Adaxes. It is due to the changes made by Microsoft on their side. However, it is also possible that the issue is just temporary. As of now, you can just make the corresponding changes on-premises using native tools.
by (300 points)
Do you happen to know what changes Microsoft made or have a link for more information? Thanks!
When there is an attempt to update something in Exchange Online but it has t be done on-premises, a certain error is returned. The error allows Adaxes to switch to performing the update on-premises. As per our investigation, Microsoft changed the error text.
We released an update including a fix for the issue. Download and What’s New links are below. For information on how to check the version of Adaxes you are using, see https://www.adaxes.com/help/CheckServiceVersion.
Upgrade instructions
Adaxes 2023.2
Download
What’s New
Adaxes 2023
Download
What’s New
Adaxes 2021.1
Download
What’s New
by (300 points)
Thank for getting this resolved! I have yet to do a version update. We are currently on version 3.16.21906. Is the update as simple as removing the old version of Adaxes and then re-installing the new? Will I need the license key or need to run a backup first? We are running a multi-server ennvironment with three servers. Thanks! image.png
In a multi-server environment, you just upgrade Adaxes service instances one by one. Taking a backup and activating your license key is not required. However, it is still a good idea to take a backup before starting the upgrade unless you already have a fresh one.
We have configured Adaxes to make accounts that have been Deprovisioned be disabled and hidden from GAL but they are still showing up in GAL. In Adaxes the account ... the sync is not completely working. Any suggestions on configurations will help. Thank you
asked Apr 2, 2021 by rujimg (40 points)
We are on 3.3.8507. We are using Adaxes to prepare users for deletion. Adaxes change the Exchange attribute to "msExchHideFromAddressLists=true". When we check our Exchange ... and they disappear. The Adaxes method does not seem to truly hide them. Ideas?
asked Oct 18, 2012 by It_helpdesk (280 points)
We have a Deprovision Rule in where we want to set "hide from address lists" in exchange, if it is not already set. but this does not work? what can i do, to first check if this is already set?
asked Oct 21, 2020 by m_st (200 points)
I am trying to send a $context.logmessage from a condition script in a Scheduled Task but I get nothing in the log. Is this not possible? Morten A. Steien
asked Jul 20, 2020 by Morten A. Steien (300 points)
Hello, I am trying out Adaxes right now and currently want to automate the steps after creating a user, more specifically O365. FYI, we have a hybrid environment and are ... 'Session'". Can someone please help me get the right script for this operation?
asked May 10, 2018 by yuvrajgill10 (100 points)
