I created a custom report based on the script supplied and it seems to be working because it returns a few results before throwing the attached error.
Everything looks correct in the report configuation and script. Any ideas what might be causing it to error out on some groups or why it would be returning a null-value?
For troubleshooting purposes, please, post here or send us (support@adaxes.com) the script you are using to generate the report in TXT format.
The code used was copied from the related answer that is linked to this question.
$groupDNString = "%param-Group%"
$groupDN = New-Object "Softerra.Adaxes.LDAP.DN" $groupDNString
    $groupCriteria = New-AdmCriteria -Type "group" -Expression {membershipType -eq "rule-based"}
    $Context.DirectorySearcher.AddCriteria($groupCriteria)
    $searchResultIterator = $Context.DirectorySearcher.ExecuteSearch()
    while ($Context.MoveNext($searchResultIterator))
        $searchResult = $searchResultIterator.Current
        $group = $Context.BindToObjectBySearchResult($searchResult)
        foreach ($rule in $group.MembershipRules)
            if ($rule.Type -ne "ADM_BUSINESSUNITMEMBERSHIPTYPE_GROUP")
            $ruleGroupDNString = $rule.Group.Get("distinguishedName")
            $ruleGroupDN = New-Object "Softerra.Adaxes.LDAP.DN" $ruleGroupDNString
            if ($groupDN -eq $ruleGroupDN)
                $Context.Items.Add($searchResult)
                break
    if ($searchResultIterator)
Unfortunately, we were not able to reproduce the error and the script works exactly as intended.
For further troubleshooting, please, post here or send us (support@adaxes.com) a screenshot of the Multi-server environment dialog. The dialog displays how many Adaxes services you have and what their versions are. For information on how to view it, see https://www.adaxes.com/help/MultiServerEnvironment.
Is there a way for me to do any debug on this script to report which object it is throwing the error on? I've tried it with multiple groups and most throw the error after returning a few results.
Not sure if this helps or not, but I am seeing this in the log: image.png Which would be at this line:
In this case, the report returned seven results before it threw the error.
The issue can occur in case there are invalid membership rules. For example, a group in a rule is deleted. We updated the script to handle such cases.
        $groupName = $Context.GetDisplayNameFromAdsPath($group.AdsPath, $True)
            if ($NULL -eq $rule.Group)
                $Context.LogMessage("Membership rules of $groupName group contain ivalid objects.", "Warning")
            if ($groupDN.CompareTo($ruleGroupDN) -eq 0)
                break
Looks like that did the trick. Thanks for the fix!
We are looking for if Adaxes has a report we can run that will tell us if there are multiple users using the same or similar passwords? Is there any tool that we can ... as another users? I appreciate any information you may be able to provide. Thank You,
asked Feb 27, 2024 by Jeff.Briand (80 points)
I am trying to create a report, that searches the extension attribute40 of all users for a username. I tried the report with "Active Directory search (param-Username)" and script. I would be glad about a tip
asked Dec 8, 2022 by boris (570 points)
I've got the following script so far using the SDK but running into an error: You cannot call a method on a null-valued expression. At line:1 char:1 + ... .BindToObjectByDN("$object.SearchResult.AdsPath.DN") $Context.Items.Add($item, $columnValues) } } } }
asked May 19, 2021 by richarddewis (260 points)
