Hi!
Is it possible with ADAxess to let our Servicedesk / Helpdesk add users to groups through the webportal, and if the group has a owner - send out a email with approval / deny links in the email from the group owner, and if the group doesnt have a owner just process the change.
/Kaj
by (650 points)
by (303k points)
Hello Kaj,
Yes, it is possible. Have a look at the following help article: https://www.adaxes.com/help/?ManageAppr ... roval.html. On step 6, select Before Adding a member to a Group.
OK I've selected Group owner as the person who should get the approval. Will this also handle the second case, I'e no group owner, and if so, auto approve the group membership?
/Kaj
Hello Kaj,
You need to add a condition to your Business Rule that will check whether a group has an owner. Finally, the rule will look like the following:
+2 votes
I'm evaluating Adaxes and so far, there have only been a few hiccups, and I am happy with the feature set. However, I'm a bit dissappointed that it does not seem to be able ... the TODO list for Adaxes? Or, am I just missing something to get them to show up?
asked Mar 3, 2023 by Michael Long (80 points)
We have a hybrid environment with On-Prem AD and Azure AD. We currently have our On-Prem AD registered (See screenshot). For us to take advantage of the Azure AD management feature ... need register Azure AD domain as well as our On-Prem AD at the same time?
asked Dec 15, 2022 by Tfarmer (160 points)
Hello, We really like the new Azure AD functionality in Adaxes. Is it possible (or planned) to managed Azure AD Custom Security Attributes (currently in Preview) using Adaxes? We have ... an AAD only user so we'd like to start with Azure attrbiutes if we can.
asked Dec 9, 2022 by Gavin.Raymen (40 points)
3,708 questions
8,565 comments
549,819 users
