Hi team,
I am wondering if Adaxes is able at all to show the ForwardingSmtpAddress of a mailbox in general? I did not find this attribute anywhere currently.
The attribute ForwardingAddress is shown as Forward to
by (2.7k points)
First of all, you can configure the required display names for all properties in Adaxes: https://www.adaxes.com/help/CustomizePropertyDisplayNames.
As for the forwarding address, you can view the recipient in the Mail Flow section in the Mailbox features tab of the Exchange properties section. For the Exchange mailboxes that have the property populated in on-premises AD, you can add the property to the view form for the corresponding types of objects. The following tutorial will be helpful: https://www.adaxes.com/help/CustomizeFormsForUserCreationAndEditing.
by (2.7k points)
I am talking about the specific attribute ForwardingSmtpAddress which is set to one of our mailboxes
Looking into the config, I have no possibility to add this specific attribute image.png
Even if I try to look for other forward related properties, I do not find itimage.png
As per our check, there is no existing exchange attribute with schema name ForwardingSmtpAddress. Nost probably, that is just the way Exchange cmdlets make the output. You can check attribtue values in AD itself. Looks like that column just outputs values of the Proxy Addresses (schema name proxyAddresses) property. The only address for forwarding is exactly the only you see in the settings and it just looks to be empty for the account in question. The attribute schema name is forwardingAddress and you can check its value in AD as well.
by (2.7k points)
it seems this field is not available in AD, however in the O365 object. From my understanding, any O365 related information in Adaxes is read from the online object, no? So this information should be also visible to the object in Adaxes, otherwise it looks like to hepldesk there is no forwarding set, however it is set.
It depends on the Exchange recipient type. Your assumption is correct for pure online recipients and for remote mailboxes.
Yes, that is correct. As per our tests setting the Forward to an internal email address option in Exchange Online is properly reflected in Adaxes. For troubleshooting purposes, please, do the following:
  • Post here or send us (support@adaxes.com) a screenshot of the Multi-server environment dialog. The dialog displays how many Adaxes services you have and what their versions are. For information on how to view it, see https://www.adaxes.com/help/MultiServerEnvironment.
  • Send us (support@adaxes.com) a full copy of the Adaxes Event Log in EVTX format. For information on how to view the log, have a look at the following help article: https://www.adaxes.com/help/ServiceEventLog.
Hello, We need to be able to put the ticket number into the custom command 'Deprovision'. Action -> Modify the user: set description to [ ... deprovision process set adminDescription with ticket number run Custom Command 'Deprovision' regards Helmut
asked Oct 14, 2020 by a423385 (510 points)
I added the Password last set field to the Admin view but when I click on edit it allows the admin user to change the value. Adaxes correclty handel Bad Password time and Bad password ... last set, so I guest there is a way but I can not find it. Thanks you
asked Dec 19, 2019 by tomlaf (60 points)
Issue The Active Directory Federation Services (ADFS) master key that decrypts ADFS certificates is stored in Active Directory, in the thumbnailPhoto attribute of a contact object ... ,CN=Program Data,DC=domain,DC=com container via native AD access control.
asked Mar 28, 2025 by Adaxes (620 points)
Environment: Adaxes REST API, called from ServiceNow. Auth via Adm-Authorization header with a service-account token (search + create work). Target: Entra distribution groups (adm- ... this isn't a role permission gap before pursuing it as an API issue.
asked Jul 29 by ZoomGhost (390 points)
