Hello Support-Team,
we are using Smartcards for Windows logon.
Some users get an additional PIN Dialog after they launch the Adaxes Administration Console.
This also happens every time they unlock a Session.
Is this a known issue? Is there a fix?
by (100 points)
by (306k points)
Adaxes uses the standard .NET methods for authentication, including any operations with smart cards. We've already experienced a similar issue with one of our customers, and eventually it got fixed after updating the smart card driver software. Any other smart cards that we tested with work OK. So, we suggest that you turn to your smart card hardware manufacturer with this issue.
by (100 points)
it is interesting, that the PIN Dialog pops up a while after the Administration Console is up and running. Not at the beginning.
As far as I know a PIN Dialog is only needed if a Software tries to access the private key of a certificate. Is there any mechanism in the Administration Console, which needs an authentication after it is already running a while?
by (306k points)
No, there is no such mechanism.
Hi Version 2018.2.Update 1 Option is missing on View OrganizationalUnits Views Actions. It's there for ditto groups and users. Said in another way - the option is selected by default, leaving out the possibility NOT to display within a box. - Thanks
asked Nov 29, 2018 by Boxx.dk (2.6k points)
Our management team is requiring that our accounts be protected with a smart card. We are using Yubikey smartcards and need to enable the ability to authenticate with the web ... web interface with our smart cards. Can this be done? Is there a guide?
asked Oct 21, 2020 by mark.it.admin (2.3k points)
Hello, we have an internal PKI-setup and are using SmartCards for many administrative tasks. Our IT-security department has asked us to implement Smartcard-Authentication on one of ... . Could you please advise what we could do? Thank you very much! HarryNew
asked Jan 25, 2019 by HarryNew (270 points)
Hi, I'm wondering if there is a way round the following "issue" we have. We are running 2018.2 (3.10.16008.0 x64) with Self-Service Client 1.3.7797.0. A ... given a choice of sign-in options, just go straight to Username & Password? Many thanks, Simon
asked Jan 17, 2019 by simontorroni (70 points)
Hello, On the "create user" form i have a custom Field "Sophos VIP User". Would it be possible to only show another property, where the user is asked to enter a ... . Or is it only possible to add a non required additional date property? Kind regards, Fabian
asked Jun 6, 2024 by fabian.p (380 points)
