After upgrading to version 2025.1 we need to rewrite al lot of powershell scripts.
We have a problem with using the ConfluencePS powershell module that is used to write info to Confluence.
When we run the scripts on our pc under Powershell V7, all is working fine but when running them in Adaxes they all give an error.
With a test script that only does: Import-Module -Name 'C:\program files\powershell\7\Modules\ConfluencePS\2.5.1\ConfluencePS.psd1'
We get the following error:
PowerShell script 'test Wim' produced the following output: Could not find a part of the path 'C:\Program Files\Softerra\Adaxes 3\Service\ref\System.Runtime.dll'. Stack trace: at , C:\program files\powershell\7\Modules\ConfluencePS\2.5.1\ConfluencePS.psm1: line 4 at , : line 1
Can you explain what is going wrong here as the PS Module does work on other PS V7 environments?
by (40 points)
by (2.7k points)
I made a script like this and run it in PS7 to check my modules
# PowerShell 7 script: check module compatibility with timing and timeout
$seen = @{}
$modules = Get-Module -ListAvailable |
    Where-Object { $_.Name -ne $null -and -not $seen.ContainsKey($_.Name) } |
    ForEach-Object { $seen[$_.Name] = $true; $_ } |
    Select-Object Name, Version, Path
foreach ($mod in $modules) {
    try {
        $start = Get-Date
        $job = Start-Job -ScriptBlock {
            param($modName)
            Import-Module -Name $modName -ErrorAction Stop
        } -ArgumentList $mod.Name
        if (Wait-Job -Job $job -Timeout 10) {
            Receive-Job $job | Out-Null
            $end = Get-Date
            $duration = ($end - $start).TotalSeconds
            Write-Host "✅ Module $($mod.Name) imported successfully in $($duration.ToString('0.00')) sec." -ForegroundColor Green
        } else {
            Write-Host "⏳ Timeout importing module: $($mod.Name)" -ForegroundColor Yellow
            Stop-Job $job | Out-Null
    } catch {
        Write-Host "❌ Module $($mod.Name) failed to import: $($_.Exception.Message)" -ForegroundColor Red
    } finally {
        Remove-Job -Job $job -Force | Out-Null
Write-Host "`n✅ Module compatibility check completed." -ForegroundColor Cyan
As we can see from the module description, it is not documented to be tested in PowerShell 7: https://github.com/AtlassianPS/ConfluencePS/tree/master?tab=readme-ov-file. At the same time, we confirm that importing the module in Windows PowerShell 7 does not error our unlike in Adaxes. We will investigate the matter and se whether there is anything we can do about the behavior.
by (40 points)
Any news on this?
The issue was fixed in Adaxes 2025.1 Update 2. You can download it here.
Upgrade instructions
What’s New
We have a need to expose a single subsite from one of our Adaxes installations through Windows's WAP. With 2023.1 and 2023.2, I was able to add /Adaxes/api, ... ? Something like /Adaxes is only the subsite we want with no other Adaxes functionality enabled.
asked Nov 5, 2025 by jrtolle (40 points)
asked May 13, 2025 by msinger (230 points)
Hi team, We are running version 2025.1 - 3.17.23904.0 with three servers and one SQL server. Two of the three servers are used for web access behind a load ... issues if we revert to the previous version (internal database/settings and SQL logging database)?
asked Jun 1 by wintec01 (2.7k points)
Since adaxes does not support powershell 5.1 and we make use of snapins for Exchange Management Tools we are considering rolling back to 2023.2. In the changelog there is no ... any issue to roll back until we figure out a way to manage the hybrid environment?
asked May 23, 2025 by jdoucet (20 points)
Attempting to upgrade my Adaxes servers to the latest version. 1 - App server - Adaxes console is installed with Adaxes Backend service and Softerra Adaxes service. 1 - Web Server - ... do I backup the web config? Do I need to do anything with the SQL server?
asked May 15, 2025 by ADuser (180 points)
