I've noticed an issue with the new Adaxes portal that seems like a downgrade from the previous version. It's specifically about how rule-based groups and their members (groups) behave.
In the old portal, I could click on a group and get redirected to the group object (or open it in a new tab). This functionality doesn't work anymore in the new portal.
Also, when selecting a group name to copy it, the new portal includes extra parameters instead of just giving me the clean name.
        "type":2,
        "group":
                "$$refObjectInfo":null,
                "referenceType":0,
                "key":"XXX",
                "displayName":null
        "directMembersOnly":true,
        "exclude":false,
        "disabled":false
Is this behavior by design or is it a known bug? It's affecting our workflow.
by (2.7k points)
What exactly is not working? Please, provide the steps you perform with screenshots. If you face errors/warnings, please, provide screenshots as well. You can post the screnshots here or send to us at support@adaxes.com.
How exactly do you perform the operation? Please, provide screenshots of all the steps you take. Also, please, clarify how the code you provided is related to the question.
Also, , please, provide us with a screenshot of the Multi-server environment dialog. The dialog displays how many Adaxes services you have and what their versions are. For information on how to view it, see https://www.adaxes.com/help/MultiServerEnvironment. You can post the screnshots here or send to us at support@adaxes.com.
by (2.7k points)
all provided via Email including short videos of both Portals.
Thank you for the provided details. The behavior is by design and cannot be changed. However, we forwarded your feed back to the corresponding department.
Over the last day or so we have been seeing this pop up under the exchange header in adaxes portal. cmdlet Get-CASMailbox is not present in the role definition of the current user
asked Jul 3, 2023 by Jeff.Briand (80 points)
How can I create a script that does these things For internal audit. objective Even removing all groups of a disconnected user, we will still know which groups the ... in the created group (audit)-sAMAccountName-access add the (user)-sAMAccountName in members
asked Jul 2, 2022 by alancardoso (40 points)
asked Feb 1, 2024 by Lewis (40 points)
This article states that managment of shared mailboxes is added. https://www.adaxes.com/info_whats-new_2019.1.htm#exchange Where is the details on implementation? It seems like ... mismatch on what you say and what the software does and lack of instructions.
We use Server 2022 Active Directory Domain Services with the new LAPS Password Management system. Access to the old ms-Mcs-AdmPwd is no longer a valid option for displaying the ... ADaxes Just a little history - I have been using Adaxes and LAPS since 2012.
asked Aug 21, 2024 by George.Holden (60 points)
