there is a "Tutorials" link in the web interface config and its pointing to https://www.adaxes.com/tutorials_WebInterfaceCustomization.htm
But it seems this page is (at least for me) not working currently.
by (2.7k points)
Thank you for pointing out the issue. We forwarded the details to the corresponding department and apologize for the inconvenience.
Hi all, I am trying to work out what has happened to our installation of Adaxes, as scheduled deprovisioning has not been working for quite a while. Previously it was possible ... (so I presume it is returning true 100% of the time?) Any input is appreciated!
asked Apr 21, 2022 by TheLexicon (200 points)
In Web Configuration, under advanced section we have set the Iddle Sessiom time out limit to 20 minutes and also the Authentication idle time out limit to 20 minutes, however ... there is any other way we can enforce re-login after session times out ? Thanks
asked Sep 10, 2025 by tromanko (410 points)
asked May 15, 2024 by tromanko (410 points)
asked Mar 20, 2024 by tromanko (410 points)
