Hello
I am looking fro information on managing custom attributes in Adaxes.
I would like to create two custom attributes:
  1. Self Service Enrollment Stauts
  2. Object Type
While browsing and viewing columns, there is a built in "Type," however this is not available while looking at individual objects: image.png
Browsing I can see "Type." But I still need a custom attribute for Self-Service enrollment status image.png
And then when viewing an individual object, I would like to be able to have these two values (custom or otherwise) viewable. The "Type" column above is not a slectable attribute for some reason.
Software version: image.png
by (580 points)
Type is a column, not a property name. That is why it is only available in lists (reports, objects in an OU, etc.) and not on object view properties. At the same time, there is no such property that will only display a certain type of object. You can use the Object class one, but each object has multiple values in it (e.g. for a user it will be top, person, organizationalPerson, user). If you need to display just a single value (e.g. User for user accounts), it can be done using a custom text attribute (e.g. CustomAttributeText1) populated accordingly. For example, it can be done using a scheduled task like below (you will need a separate task for each type of objects). For details on how to make the property visible on a web interface form, see https://www.adaxes.com/help/CustomizeFormsForUserCreationAndEditing. image.png
Unfortunately, there is no dedicated property holding the current enrollment status of a user for password self-service. You can save the status to a custom Boolean attribute using this script and add the attribute to the user view form.
Hello, We really like the new Azure AD functionality in Adaxes. Is it possible (or planned) to managed Azure AD Custom Security Attributes (currently in Preview) using Adaxes? We have ... an AAD only user so we'd like to start with Azure attrbiutes if we can.
asked Dec 9, 2022 by Gavin.Raymen (40 points)
I have a custom adaxes attribute that I would like to utlitize in Rule Based groups; it does not look like they are available to select, however. Example: want something ... to group. Is this possible to make them visable in the Rule Based queries somehow?
asked May 28 by stevemkoenig (40 points)
