I thought I saw an option for this at some point but now I can't seem to find it (there is also the possibility I never did see such an option).
Is it possible to change the default behavior of a double-click in any find operations output to open the objects properties rather than "locate in tree"?
by (520 points)
To open the Properties dialog for an AD object you can use the Alt+Enter shortcut.
Double-clicking opens the Properties dialog when you double-click an object in the Console Tree or Result Pane.
Unfortunately this behaviour cannot be altered.
After installing the self-service client MSI, at the Windows login screen, when clicking other user, the default domain isn't available, users need to click sign in ... and this is applied but with Self-Service client installed not showing by default.
asked Jan 19 by melissa.meyer (20 points)
Hi again, My user object creation process use many business rules, one of these moving the object to the right container according to somme attributes. The problem is that sometimes, ... . I run the latest version of Adaxes (3.2.7831). Thanks for your help
asked Feb 10, 2012 by sroux (800 points)
asked Oct 24, 2022 by mightycabal (1.2k points)
Hello Support, We have reports for users who should only have the rights to see the members of a group. However, they should not have the right to open the "profile" ... report and see the result of the report and cannot do anything else? Thank you very much
asked Apr 15, 2024 by DRiVSSi (360 points)
Good Day I've found what i want and is this Scripts Repository https://www.adaxes.com/script-repository/output-the-last-time-a-distribution-list-received-mail-s122.htm. Is ... in to a Report with the addition to add one more then one Distribution? Thank you
asked May 11, 2022 by Sandberg94 (340 points)
