Is it possible to customize the client interface when creating new objects?
Just like customizing the web form - so that some fields are not displayed...?
by (500 points)
Yes, it is possible. For details, see https://www.adaxes.com/tutorials_WebInt ... diting.htm.
by (500 points)
But isnt that only for the web interface - and not for the "real" Adaxes console?
Yes, you are right. The instructions in the tutorial are only for Adaxes Web Interface. There is no possibility to modify the forms in Adaxes Administration Console.
by (500 points)
Whether it is hard to customize the client interface when creating new objects? Example: customizing the web form - so that some fields are not displayed...
asked Aug 2, 2019 by Huongle08 (50 points)
I am trying to customize the enrollment pop up page to specify the number format need, but I cannot for the life of me find the file or location where I can edit the html code needed to say this on the enrollment page, is this even possible?
asked Apr 10, 2023 by gwadmin (80 points)
I've read this article; https://www.adaxes.com/tutorials_WebInterfaceCustomization_CustomizeHelpAndSupportLinks.htm?appView=1 However, it doesn't tell me how to add or remove columns from ... by the Quick Search. I'd like to add EmployeeId. thanks, Nate
asked Apr 10, 2022 by nate2 (90 points)
How do I customize approval form so approver would get more information and context what should be approved or not? "Are you sure want to approve the request?" isn't enough. I would like to see something like "Are you sure want to approve removing user x?"
asked May 4, 2021 by juhota (230 points)
Hello Adaxes Team I would like to change the text in the approval mail. As far as I know this is currently only possible via "Custom Action Description" text. For ... Is there a way I can output the description propertie from the target-object? regards Dominik
asked Jan 31, 2021 by pudong (680 points)
