Is there a way to change the default site that shows up to adaxes instead of the IIS 7 default splash page?
by (270 points)
Hello John,
Yes, this can be easily done in IIS.
  1. On the computer where Adaxes Web Interface is installed, launch Internet Information Services (IIS) Manager.
  2. In the Connections pane, expand the server and select the web site that hosts Adaxes Web Interface.
  3. In the Home pane on the right, double-click HTTP Redirect.
  4. Select Redirect requests to this destination.
  5. In the field below, enter the URL you need (e.g. http://host.comapny.com/Adaxes for the Common Sign In page).
  6. Select Only redirect requests to content in this directory (not subdirectories).
  7. In the Actions pane on the right, click Apply.
  8. Restart IIS.
by (170 points)
  1. How to change the "host" value from hostname of the Adaxes server to another name?
There is no such possibility in Adaxes. The only way is to actually rename the computer where Adaxes is installed. If you need that only for the Web interface component, you can change the bindings in IIS for the Web site that hosts Adaxes Web interface. The following Microsoft article might be helpful: https://docs.microsoft.com/en-us/iis/configuration/system.applicationhost/sites/site/bindings/binding.
by (0 points)
What about if you requite HTTPS, , for example
User access's https://ad.company.com
This does not seem to redirect to https://ad.company.com/Adaxes
As the Above is an HTTP redirect
That is also something that you should be able to configure using IIS redirects. Unfortunately, we were not able to find a dedicated article. You can try checking the official IIS web site: https://www.iis.net.
asked Oct 30, 2019 by Adaxes (660 points)
+2 votes
Hello, When i'm trying to get exchange information on the adaxes site, it got the following error message: "The input object cannot be bound to any ... Tools installed on adaxaes server - Adaxes User has Exchange Administrator Rigths on the mailserver
asked Sep 10, 2013 by wies.j (20 points)
We are using Adaxes Directory Object Picker for selecting Distribution Group members. We create external recipients as Exchange Online MailContacts (via New-MailContact). These contacts: are ... Context: We are using cloud-only contacts (no on-prem AD sync).
asked May 27 by IwistIT (140 points)
We have a preoperty pattern for accepted Country names which has a list of codes. For our case country code VM which "Vietnam" and I believe based on some google research "Viet Nam" is also correct.
asked Jul 12, 2024 by Vish539 (500 points)
We are planning to use Adaxes in our environment and before proceeding, we need to understand the firewall port requirements for Adaxes service to work. What are the firewall ports needed between Adaxes and AD domain controller?
asked Jan 24, 2024 by Renugopal (120 points)
