My org has decided to create LDAP fields to replace some of the custom Adaxes fields. how can I copy the following fields?
adm-CustomAttibuteDate1 > ldapDate1
adm-CustomAttibuteText1 > ldapInteger1
I need to be able to run the job for all user object in AD.
by (1.3k points)
You can create a Scheduled Task configured for the User object type that will run just once. The task will update values of new attributes with those of corresponding Adaxes custom attributes using value references. For information on how to create Scheduled Tasks, see https://www.adaxes.com/tutorials_Automa ... gement.htm. Additionally, the task can also clear the custom attributes if required. Finally, it will look like the following:
by (1.3k points)
I am not able to type in the box to to set the field I'm trying to copy from. I have attached both Screen Shot
Adaxes version
2017.2
3.8.14823.0
When using the Update the User action to modify dates, you need to use the Edit button to specify the value to be set.
As we understand, usrAdaxesSN-NonBillID is an Integer property. It means that in the New Value field, you can enter only digits. In Adaxes version 2017.2 it was not possible to enter value references for Integer properties in the action.
by (1.3k points)
Okay, So how can I copy one field into another if I can't use value references? Is there a way using powershell?
Yes, it is possible using PowerShell. You will need a script like below. In the script:
  • $propertyToCopy - Specifies the LDAP name of the property whose value will be copied to another property.
  • $propertyToSet- Specifies the LDAP name of the property to update.
$propertyToCopy = "adm-CustomAttributeText1" # TODO: modify me
$propertyToSet = "adm-CustomAttributeInt1" # TODO: modify me
    $valueToCopy = $Context.TargetObject.Get($propertyToCopy)
    $valueToCopy = $NULL
$Context.TargetObject.Put($propertyToSet, $valueToCopy)
For the action copy user, under object selection I choose objects selected by the user, copying from the user who gets the email. Location selection is the OU I ... the source user. Is it possible to erase that automatically and reapply the property pattern?
asked Mar 24, 2023 by GronTron (390 points)
Recently we started getting this error in Adaxes Some fields couldn't be loaded. Failed to get the mailbox usage information. Failed to commit the change on object " ... are correct but the issue persists. This is occuring with Exchange Online only:
asked May 21, 2025 by curtisa (350 points)
I would like to have the possibility to use different icons for AD groups. I have groups for file permissions, applications, mailboxes, etc. For each group type I ... do this without schema extension? or will this be possible in the future? regards pudong
asked May 6, 2022 by pudong (680 points)
Is it possible to change the visibility of required fields in Adaxes 2020.1 as it was with the old Webinterface and custom css for every Webinterface-instance? Thanks
asked Nov 6, 2020 by Michel (20 points)
