Is it possible to change the visibility of required fields in Adaxes 2020.1 as it was with the old Webinterface and custom css for every Webinterface-instance?
related to an answer for: Changing font size on self service page
Unfortunately, there is no possibility to change the style of displaying fields in the Web Interface.
Is there a way to configure the module "Member of" in a "View user"-action as purely read only? As it stands now we are able to navigate to a seperate viewing page ... needs write-access to AD, we can't specify purely read-rights via the security role either.
asked Mar 8, 2024 by Handernye (120 points)
When using the administration console (not the web console), we would like to be able to customize the fields that are shown on the different tabs of the user properties ... in the web interface but I don't see the same option for the administration console.
asked Jan 27, 2020 by abarker5 (80 points)
What are the minimum security role requirements required for vieiwing management history within the Web GUI. I have granted the following to any authenticated users They are ... permissions should be required for allowing viewing this report in the Web GUI.
asked Feb 10, 2025 by KoleArmstrong (170 points)
Hello, I am not getting email responses from support because of a technical problem. In the meantime, I figured for I would post here. I am using the new heldesk web ... how the helpdesk interface is configured and what the user's screen looks like: Thanks.
asked Jul 20, 2018 by Jasonmh (540 points)
