Greetings,
I am currently evaluating Adaxes and was wondering,
how well can it handle an AD that is close to 50GB in size?
Does Adaxes update ACL's on the objects?
Does it basically store an entire copy of the forest (or domains) in the database installed by the product?
Thanks for your Time
Ron Hagerman
by (50 points)
Hello Ron,
The performance of Adaxes almost isn't affected by the size of your AD.
Adaxes acts as a proxy between you and AD, which means that each operation is preprocessed by Adaxes and then executed in AD.
The amount of time taken by the preprocessing depends only on the amount of objects affected by the operation rather than on the whole amount of objects in your directory.
No, Adaxes controls access to AD resources via Security Roles, and native AD permissions are not modified.
No. The Configuration Storage Server installed with the product stores only configuration objects of Adaxes.
by (50 points)
Thanks Eugene, that's exactly what I was hoping for :)
Hello How do I reset a user's security questions? They forgot their answers. Thank you!
asked Aug 24 by apruitt (560 points)
The new version of Adaxes says it uses Powershell 7 and Powershell 5.1 scripts may need to be re-written. I have so many scripts using a combination of ... several different web views for several different teams and uses. Will existing permissions change?
asked Apr 30, 2025 by mightycabal (1.2k points)
Morning team, I have two questions about reports I created a container for our helpdesk and adding reports there. Each time a new report was added, I need to ... country name should be Germany and company name should be MyCompany Is that possible? Thanks!
asked Aug 14, 2024 by wintec01 (2.6k points)
When building a form, is there a way I can request the user to answer questions? I understand there is the adm-customattributes that aren't stored in AD, but I don' ... the reason why, rather than just seeing "What" change is being requested. Thank You!
asked Mar 1, 2023 by Edogstraus00 (590 points)
Is there anyway we can get an Adaxes administrator to be able to access the security the questions and answers from the “Password Self-Service Policies” portal for our users?
asked Feb 17, 2022 by JoeG (40 points)
