Is there a way to customize Adaxes console forms?
by (120 points)
Currently, there is no such a functionality in Adaxes, but we have a similar feature in our backlog. It will be available in one of the future releases.
thx, for the information.
I have a last question. Will there be any exchange signature deployment in the next releases of Adaxes?
No, we are currently not planning to support this, but thanks for the suggestion!
When using the administration console (not the web console), we would like to be able to customize the fields that are shown on the different tabs of the user properties ... in the web interface but I don't see the same option for the administration console.
asked Jan 27, 2020 by abarker5 (80 points)
Running 2018.1 Our helpdesk staff have the Admin Console installed on their workstations with limited permissions granted to their accounts. They are in charge of new user additions ( ... seem to be a way to simply create a new user via Custom Command either.
asked Jul 27, 2018 by bradenmcg (260 points)
Hello Is there any way to enable default sorting in the Adaxes Administration Console for the "Members" and "Member" lists? I always have to click on "name" ... Adaxes Administration Console 2021.1 version 3.14.18920.0 (64bit) Thanks and greetings Dominik
asked May 18, 2021 by pudong (680 points)
HI support, We mostly use the Console. Are you think about to enable Two Factor Authentication for the Adaxes Console as well? That would increase the security level enormously. Sincerely yours, Chris
asked Feb 10, 2020 by Napoleon (700 points)
When building a form, is there a way I can request the user to answer questions? I understand there is the adm-customattributes that aren't stored in AD, but I don' ... the reason why, rather than just seeing "What" change is being requested. Thank You!
asked Mar 1, 2023 by Edogstraus00 (570 points)
3,737 questions
550,311 users
