How can I retrieve the mailbox usage of mailboxes as per the screenshots on your website and various online reviews?
I've not been able to find it.
Below is a screenshot of what I am looking for.
Thanks.
by (180 points)
This is available in the Web interface. To view mailbox usage statistics of a user:
  1. Login to Adaxes Web interface.
  2. Navigate to a a user that you want to view mailbox usage statistics of.
  3. Click on the user to view the user's properties.
  4. In the Exchange Properties section, activate the Mailbox Usage tab.
If you don't see the Exchange Properties section when viewing a user, see step 6 under Exchange Properties in the following tutorial: http://www.adaxes.com/tutorials_WebInte ... ewexchprop for information on how to add it.
Super! Thank you! I'm seeing it now.
Are there any mailbox size reports or would this be a feature request?]
Currently, there is no such report in Adaxes, but for the next version we are going to completely rework the Reports subsystem, which will allow you to create custom reports on your own. Starting from the next version, it will be possible to create mailbox size reports.
For now, you can achieve this using a PowerShell script. You can create a script that generates a report on the sizes of the mailboxes you need in an HTML or CSV format and saves the report to a certain file share or sends it by e-mail. Also, you can create a Custom Command or a Scheduled Task executing the script to be able to run the report on demand or on a certain schedule.
To help you with the scripts, have a look at the following samples:
If you need more assistance with the script, we will help you.
Recently we started getting this error in Adaxes Some fields couldn't be loaded. Failed to get the mailbox usage information. Failed to commit the change on object " ... are correct but the issue persists. This is occuring with Exchange Online only:
asked May 21 by curtisa (350 points)
Is there a way for Adaxes to report once we are reaching our license limit within Adaxes e.g. when we reach 90% usage to send us an email? (if we have 1000 user license to get an alert when we have used 900)
asked Jul 7, 2020 by peggleg (110 points)
Is it intended for Adaxes licenses count to include service accounts? Is it possible to flag service accounts so they do not count against our licenses or is there a place ... so they aren't counted, but of course aren't enabled for various Adaxes features?
asked Nov 11, 2019 by rosshouck (20 points)
Dear Adaxes support, can you please advise if there an option to release memory, used by Adaxes service? I'm facing an issue with 2019.1 that after ... ) $computer.SetInfo() } } } Remove-Module $ConfigMgrModulePath -ErrorAction SilentlyContinue Thanks, Dmytro
asked Jun 25, 2019 by Dmytro.Rudyi (920 points)
Hello, I have a scheduled task running daily at 1am. After that the Softerra.Adaxes.Service.exe process is using most of the available memory and brings the server to ... the remote session and release resources if ($session) { Remove-PSSession $session } }
asked Jun 14, 2019 by ryan_breneman (920 points)
3,738 questions
8,640 comments
550,341 users
