Hi all,
Since few days, we're facing regularly connection issue between our O365 tenant and Adaxes.
A simple restart of the Adaxes service solve the issue, for some days.
Below an error from Adaxes event log
Softerra.Adaxes.CommandPipeline.CommandProcessingException: The following command threw an exception while being executed: Activate an Office 365 account for 'CROWLEY, Keren (eu.loi.net\EU99-Stores\Locations\United Kingdom\Users)': set Location to 'GB', enable Office 365 Enterprise E3. ---> Softerra.Adaxes.Adsi.DirectoryComException (0x80072035): Failed to create an Office 365 account. An error occurred during authentication. Please retry your operation. If this problem persists, contact Technical Support.
at #5.#Fb.#x3(AdmO365AccountProperties accountProperties, #7 propertyAccessor)
at #5.#Fb.#r3(AdmO365AccountProperties accountProperties, #7 propertyAccessor)
at #5.#Jb.WriteProperties(WritePropertiesContext context, AdmSerializablePropertyList propertyList)
at #5.#Jb.WriteProperties(WritePropertiesContext context)
at Softerra.Adaxes.Adsi.AdmObject.ModifyObject(WritePropertiesContext writePropertiesContext)
at Softerra.Adaxes.Adsi.AdmObject.SetInfoEx(Object props)
at Softerra.Adaxes.CommandPipeline.Actions.SetPropertiesAction.ExecuteAction(IAdmTop targetObject, AdmPropertyList propertyListCopy)
at Softerra.Adaxes.CommandPipeline.Actions.ActionBase.Execute(IAdmTop targetObjectArg)
at Softerra.Adaxes.CommandPipeline.Actions.ActionBase.Execute(ICommand command)
Thanks in advance for your help
Kind regards
by (740 points)
It is a well-known issue that occurs because authentication in Office 365 fails. We've already implemented a workaround for it and will release a minor update to Adaxes 2014.1 that will fix the issue within the nearest few days. For now, to resolve the issue, you can restart Adaxes service.
by (740 points)
Hi Guys,
Thanks for your reply.
We'll try to live with that until you release the update :lol:
The "patch" will be available in Download section ?
Regards
Actually, the minor update will be released very soon. Probably, at the beginning of the next week. It will not be just a 'patch', but a new version of Adaxes that will be available at the following page: http://www.adaxes.com/download_direct.htm, where you can always find the latest version of Adaxes. Also, have a look at the Upgrade Procedure, which remains the same no matter whether you upgrade to a minor update or a major version.
by (740 points)
Hello guys,
Any news on release date please ?
thanks in advance
King regards
The issue has been fixed in Update 3 to Adaxes 2014.1. You can download the latest release here.
Upgrade instructions
Complete list of bug fixes and minor improvements in the Minor Update
I am having a difficult time wrangling Adaxes' custom attributes on v2025.1 to use them as placeholders to sync later or just have data visible in adaxes only. We are ... I bulk import from CSV values to adm-CustomAttribute and verify that they were saved?
asked 4 days ago by AvenuesRecovery (90 points)
asked Oct 25, 2025 by apruitt (430 points)
asked Oct 10, 2025 by apruitt (430 points)
Hello, We are currently allowing users to submit requests for new user accounts within the domain. By default, the logon name is being formatted as %firstname%.%lastname% However this ... pre-Windows-2000 user logon name. Is there a way to work around this?
asked Dec 11, 2020 by sirslimjim (480 points)
Hey Guys We have some issues with new meeting rooms that we have created. Previously we used to have on-premise exchange but switched to office365. Before doing ... OU but the interface are different. under exchange properties they are different aswell.
asked Sep 18, 2019 by seanr (70 points)
