We are currently running version 3.7.10510.0
I have a user that is trying to run reports out of the web interface. When he tries to run any report he is receiving no objects to be found. I have created a test user that has the same groups and rights as him and I can run the reports with no issues.
Any idea why the user cannot see any results for the reporting?
Thanks.
by (50 points)
To be able to view objects, users need to be assigned appropriate permissions granted with the help of Adaxes Security Roles. The no objects to be found message means that the report cannot display any objects that the user can view. You need to check which Security Roles are assigned to the user and whether they grant sufficient permissions to view objects. For information on how to do this, see the following FAQ article: How can I view the permissions granted to a user?.
Also, pay attention that Deny permissions always override Allow permissions, so if any of the Roles grants permissions to view objects, and another Role denies the permissions, the Role that denies the permissions will always prevail.
Here is an example: In Azure the manager shows populated: In Adaxes it shows a blank:
asked Dec 2, 2022 by adaxes_user2 (40 points)
Hi I'm having an issue saving some arrays to multivalue attributes in a scheduled task script and I cannot see what the issue is. Import-Module ActiveDirectory $domains = (Get ... and both are in the same domain. Any help will be much appreciated. Thanks Matt
asked Mar 25, 2021 by chappers77 (2.0k points)
Does Adaxes offer inventory reporting? Would like to be able to see what computers/tablets/etc. are assigned to each user.
asked Jan 19, 2021 by jbonasera (20 points)
Can the Password Self Service statistics be presented to end users in a report? The only way I have been able to find the information is in the Admin console ... I would like to be able to provide it to our Helpdesk as a report of some type. Thank you.
asked Oct 28, 2015 by hms.scott (220 points)
I am trying to get a security role report similar to that in the post Security Role - Report I have also read up on the post at http://www.adaxes.com ... ,CN=Builtin,CN=Security Roles,CN=Access Control,CN=Configuration Objects,CN=Adaxes Configuration,CN=Adaxes
asked Aug 5, 2015 by jakesomething (190 points)
3,739 questions
550,351 users
