Hi Guys,
We have two separate web UI for our HR and service desk. On HR one we have yellow bar with such text:
"You don't have any permissions to read properties of your account. Some features of the Web Interface will not be available."
Is it possible to hide it somehow?
Also, we'd like to hide information about OU of the selected user. Let's say I choose user from the search, after that just above the Select button I have info about user in this format: John Doe (acme.com\Users\West). I'd like to display only DisplayName in this case "John Doe".
by (510 points)
First of all, could you specify what exactly would you like to achieve? Do you want to simply remove the message or try to identify which permissions they are lacking that the message appears? In other words, did you deny the permissions for HR guys to view properties of their accounts deliberately?
Have a look at step 6 in the following tutorial: http://www.adaxes.com/tutorials_WebInte ... onents.htm.
Hello, as you can see in the attached picture some of the words are in English and some in German. As I can oversee it's the only page with that behaviour - all other pages are in English. Regards.
asked Jan 2, 2018 by HorstR (460 points)
Is it possible to hide the filter and the my properties section in the header?
asked May 6, 2020 by lbressan (120 points)
Hi - How can I remove the option of allowing "Copy User Groups" during the copy user process in the interface. I'd like to have it hidden but still active so to not allow our HR team to accidently unclick it during the process.
asked Oct 15, 2019 by 6FigureMission (140 points)
To the left of the user object there are several custom commands showing. I don't want our service desk to see them. Why are they showing? How do I remove them. Must be something simple. They only see these when looking at a user Object.
asked Jan 17, 2024 by mightycabal (1.2k points)
