as you can see in the attached picture some of the words are in English and some in German.
As I can oversee it's the only page with that behaviour - all other pages are in English.
Regards.
by (460 points)
Hello Horst,
Could you provide us with the backup of your Adaxes Web Interface configuration? You can send it to support[at]adaxes.com. For information on how to make a backup, have a look at the following help article: http://www.adaxes.com/help/?HowDoI.Conf ... onfig.html.
Did you install German or English version of Adaxes?
What locale is configured on the computer where Adaxes Web Interface Customization Tool is installed?
by (460 points)
sorry for the late response:
- we installed the English version of Adaxes
- the server settings (language, keyboard) are German
I'll send the backup in some minutes.
Regards.
Hello Horst,
For troubleshooting purposes, check whether the Softerra.Adaxes.Web.UI.Configuration.resources.dll file is present in the de folder on the computer where the Web Interface is installed. By default, the folder is located in the C:\Program Files\Softerra\Adaxes 3\Web Interface\ folder.
If the file is not present, do the following:
  1. On the computer where Adaxes Web Interface is installed, close Adaxes Web Interface Customization Tool.
  2. Open Programs and Features from the Control Panel.
  3. Right-click Softerra Adaxes and click Repair in the context menu.
by (460 points)
we executed the repair function but the required dll is still missing.
Regards,
Horst
Hello Horst,
What version of Adaxes are you currently using?
To check that, do the following:
  2. Right-click your service.
Also, could you specify whether you have 64-bit or 32-bit version installed?
Is it possible to trim the values before saving the values? e.g., when someone copies and pastes a first name, it has a trailing space and this is carried over to AD too. Is it possible to trim this value?
asked Oct 22, 2013 by sdavidson (730 points)
Hi. I was wondering where I could change the text highlighted on the picture below? There is still no doubt what the product being used is. On the bottom, it's very clearly states that information.
asked Aug 5, 2011 by Brandur (100 points)
Hi Guys, We have two separate web UI for our HR and service desk. On HR one we have yellow bar with such text: "You don't have any permissions to read properties of your ... (acme.com\Users\West). I'd like to display only DisplayName in this case "John Doe".
asked Mar 20, 2015 by axmaster (510 points)
Hello! There seems to be an error in the German translation of the attribute Job Title. In Adaxes it is translated as Anrede, which actually means salutation, instead of the ... in German language Active Directory. Is there a way to fix this? Best regards Erik
asked Jun 20, 2014 by eventit (160 points)
I am looking for a way to view the exact reason why someone would see the error below when accessing the web interface. It would be helpful to see this in a log ... "user attempted to access Web Interface section A, but is lacking the permission XYZ..."
asked Aug 6 by apruitt (560 points)
