Is there a way to use a Business Unit as a condition of a Business Rule? There's a condition called "If an Initiator is a member of ", but not a generic "If is a member of <business unit"
It seems to me to be a logical use for Business Units, but I've just purchased the tool, so I'm still learning and I might have missed it.
Thx!
--Joel
by (510 points)
Update 2019
Starting with version 2019.1, the If the object belongs to condition is available in business rules, custom commands and scheduled tasks.
Original
Hello Joel,
The If is a member of condition is not present in Adaxes because there is basically no need for it. When you define the Activity Scope for a Business Rule or Scheduled Task, you can include or exclude a Business Unit, which is approximately the same as if you've put the If is / is not a member of condition in the rule or task. However, if you can't do without this condition, you can easily check whether an object is a mmber of a Business unit with the help of a PowerShell script. For example, the following script returns True if the target object on which a Business Rule, Custom Command or Scheduled Task is executed, is a member of a Business Unit named My Unit:
$businessUnitName = "My Unit" # TODO: modify me
# Search Business Units with the name specified
$businessUnitsPath = $Context.GetWellKnownContainerPath("BusinessUnits")
$searcher = $Context.BindToObject($businessUnitsPath)
$searcher.SearchFilter = "(&(objectCategory=adm-BusinessUnit)(name=$businessUnitName))"
    $units = $searchResult.FetchAll()
    if ($units.Count -eq 0)
        $Context.LogMessage("No Business Units with name '$businessUnitName' found.", "Warning")
    foreach ($unitId in $units)
        $unit = $Context.BindToObject($unitId.AdsPath)
        if ($unit.IsMember($Context.TargetObject))
    $searchResult.Dispose()
The script must be used with the If PowerShell script returns true condition. For information on how to add and configure such a condition, see step 6 in the following tutorial: http://www.adaxes.com/tutorials_Simplif ... Script.htm.
by (510 points)
Thank you! That was what I was missing!
--Joel
Hi We have a set of business rules which are used for creating new distribution lists, these rules all have the same activity scope of a number of OUs, but the number of OUs ... when a new OU is created, it's not missed from the activity scope. Thanks Matt
asked May 12, 2022 by chappers77 (2.0k points)
I created a scheduled task (to export data) with a domain as its activity scope, runs perfectly. I modified it to use a Business Unit as its activity scope, now it ... the task effective for" should be checked, but the property is not editable in the dialog.
asked Mar 23, 2015 by sbanks (270 points)
asked Feb 11 by wrobin68 (40 points)
