Greetings, I am currently evaluating Adaxes and was wondering,
how well can it handle an AD that is close to 50GB in size? Does Adaxes update ACL's on the objects? Does it basically store an entire copy of the forest (or domains) in the database installed by the product?
Thanks for your Time
Adaxes should work just fine with your Active Directory.
Adaxes does not modify native Active directory permissions. Also, it does not extend your AD schema. If you uninstall Softerra Adaxes, you can use Active Directory just as you did before the product installation.
No, Adaxes does not store a copy of your Active Directory forests or domains.
Can you point me to documentation to upgrade from Adaxes 2019.2 ver 3.1.2.174230 to the current version please?
asked Jun 16, 2020 by msylvester (60 points)
Can anyone provide the instructions contain in the now broken link? I realize new Adaxes doesn't require this, but still have an older install that doesn't allow manual override via GUI. Thanks.
asked Oct 13, 2022 by okiad (20 points)
I am trying to use a script to set a users AccountExpires attribute. However, I want there to be an approval sent and I am ... = $False $Context.SubmitForApproval($approvers, $managerOfRequestorIsApprover, $false, $false, $false) }
asked Dec 1, 2023 by mightycabal (1.2k points)
First off, thank you for not shoving AI into Adaxes and for continuing to improve it. I'm trying to set property pattern validation for new user creation and I'm a ... least two 'smart' quotes to trigger the error message. Any assistance is much appreciated
asked 5 hours ago by SoftShark (20 points)
I need some assistance combining 1: https://www.adaxes.com/questions/9428/daily-scheduled-task-to-disable-inactive-users With 2: https://www.adaxes.com/questions/1509/inactive-users For ... a custom paramater for $days ? For 2: "less or equal" isn't an option.
asked Dec 30, 2024 by apruitt (450 points)
