I hope someone can help me with a specific script. I have tried to put 2 or 3 together that I have found on here but not having much luck.
I am looking to have a unique username with a 10 character limit (of first name initial + surname), if not unique to add a number at the end.
I was then looking to have a unique UPN (firstname.lastname@domain.com), if not unique to add a number at the end.
Is someone able to help me put this together please?
I have come across this - https://www.adaxes.com/questions/436/check-for-duplicate-upn, but it doesn't seesm to be quite what I'm after.
Any help would be appreciated.
by (40 points)
You can use the Username has a length limitation script from the following article in our script repository: https://www.adaxes.com/script-repository/automatically-add-a-digit-to-the-username-if-it-is-not-unique-s298.htm. It works exactly the way you need.
by (40 points)
Hey thank you for this, sorry yes this is one of the ones I tried to follow.
The issue is that it sets the UPN to the unique username.
I need it to have a unique firstname.last@domain.com (Joe.Bloggs1@domain.com).
The above is fine for the pre W2000 username, but not the UPN unfortunately.
That second part is the bit I'm mainly struggling on currently
Thank you for clarifying. For us to update the script to meet your needs, please, specify the following:
  1. Should the prefix part of UPN also be limited in length?
  2. If the initial prefix (FirstName.LastName) is not unique, should the script add a digit to the prefix until UPN is unique? If not, what should the script do to make UPN unique?
by (40 points)
Hey,
No limit to the UPN, just full first name. and last name.
And yes to your second question, simply add a digit until UPN is unique.
Import-Module Adaxes
$emailsuffix = "domain.co.uk"
$maximumLength = 10
$firstname = "%firstname%"
$surname = "%surname%"
function IsUserNameUnique($username)
   $user = Get-AdmUser $username -erroraction silentlycontinue
   return $user -eq $Null
# Get the username
$username = $Context.GetModifiedPropertyValue("samAccountName")
# Check user name Length
if ($username.Length -gt $maximumLength)
    $username = $username.SubString(0 , $maximumLength)
elseif (IsUserNameUnique($username))
    # Username is unique
# If the username is not unique, generate a unique one
$uniqueUsername = $username
for ($i = 1; $True; $i++)
    if (IsUserNameUnique($uniqueUsername))
        break
    $difference = $maximumLength - $username.Length - $i.ToString().Length
    if ($difference -lt 0)
        $username = $username.Substring(0, $username.Length + $difference)
    if ([System.String]::IsNullOrEmpty($username))
        $Context.Cancel("Unable to generate a unique username, because the number length exceeds the maximum length of the username")
    $uniqueUsername = $username + $i;
# Update User Logon Name (pre-Windows 2000)
$Context.SetModifiedPropertyValue("samAccountName", $uniqueUsername)
Function GetUserPrincipalname {
        $result = "$($firstname).$($surname)@$($emailsuffix)"
        $int = 2
        $output = Get-ADUser -filter "UserPrincipalName -eq '$result'"
        $tmpresult = $result
        Do {
                $output = Get-ADUser -filter "UserPrincipalName -eq '$tmpresult'"
                if ($output -eq $Null) {
                    $result = $($tmpresult)
                } else {
                    $result = "$($firstname).$($surname)$($int)@$($emailsuffix)"
                    $tmpresult = $($result)
                    $int = $int + 1
        Until ($output -eq $Null)
    Return $result
$userLogonName = GetUserPrincipalname
$Context.SetModifiedPropertyValue("userPrincipalName", $userLogonName)
    $Context.LogMessage("The name has been changed to " + $objectName `
      + ".", "Information")
Thank you for the confirmation. Find the updated script below. In the script:
  • $maximumLength - Specifies the maximum length of the username.
  • $upnPrefix - Specifies a template for generating the UPN prefix. You can use value references in the template. In your case, it should be "%firstname%.%lastname%"
$maximumLength = 8 # TODO: modify me
$upnPrefix = "%firstname%.%lastname%" # TODO: modify me
function IsUserValueUnique($filter)
   $user = Get-AdmUser -LdapFilter $filter -erroraction silentlycontinue
# Get the username
# User Logon Name (pre-Windows 2000)
    if (IsUserValueUnique "(sAMAccountName=$uniqueUsername)")
        break
# User Logon Name
$upnSuffix = $Context.GetObjectDomain("%distinguishedName%")
$uniqueUPN = "$upnPrefix@$upnSuffix"
    if (IsUserValueUnique "(userPrincipalName=$uniqueUPN)")
        break
    $uniqueUPN = "$upnPrefix$i@$upnSuffix"
$Context.SetModifiedPropertyValue("userPrincipalName", $uniqueUPN)
$Context.LogMessage("The username has been changed to " + $uniqueUPN `
by (40 points)
I can't thank you enough, I kept editing my post as the more I looked at it the more problems I noticed. But still couldn't get it to work.
Your code works beautifully, the only thing is that the UPN suffix seems to be defaulting to the incorrect one.
I have specified it at the start of the code as follows: $upnSuffix = "domain.com"
But it doesn't seem to make a difference, am I missing something?
by (40 points)
Sorry I've just seen that it is specified further down, I have just changed that part to meet our requirements. Thanks again :)
We are currently using the script below to check for a unique username/upn. If the name is not unique, it adds a number to the end. In the Adaxes logs, everything appears ... .LogMessage("The username has been changed to " + $uniqueUPN ` + ".", "Information")
asked Feb 14, 2025 by cewilson (300 points)
Due to some of the systems we have, we must limit our logon names to 8 characters. When I set the Value Length to Maximum 8, the result when creating a new account ... get a popup "Invalid Value Length". Is there a way to autopopulate with only 8 characters?
asked Mar 18, 2013 by Kikaida (1.1k points)
Trying to configure a custom launcher in Thycotic Secret Server that will launch Adaxes on the user's local machine with the username and password passed as parameters. Has anyone made this work?
asked May 20, 2022 by amillard (20 points)
Hi, I am looking for a solution which checks if the username ist unique with the following requirements: If [first letter of first name].[last name] is not possible as username ... letter of first name].[last name]2 I' am looking forward to a hint. Thanks
asked Feb 6, 2023 by boris (570 points)
Has anyone ever had the business requirement that the usernames of new users be unique across all of the managed domains in the environment? It is easy enough to run a ... the run as service account understand to look further into the other domains as well?
asked Jul 22, 2016 by strikk (360 points)
