Greetings!
Is there a way to be alerted via email and/or SMS when specific AD group changes have been made through the Adaxes web console? Currently I am looking at the second PowerShell script from the Script Repository (http://www.adaxes.com/script-repository ... s-s289.htm), but unfortunately that returns information from the logs on the DC's and not the Adaxes logs. The logs on the DC's do not show the actual technician that made the changes, only the Adaxes service account. Also, I am only looking to monitor a few AD groups, and not all.
Any insight would be appreciated.
Marty Bouillon
by (150 points)
by (273k points)
Have a look at the following tutorial: http://www.adaxes.com/tutorials_Automat ... Groups.htm.
In step 3 of the tutorial you will need to select After Adding or removing a member from a Group.
In step 4 of the tutorial you can select Send SMS action instead of Send e-mail notification.
You can have both E-mail and SMS sent, to do so:
  1. After performing step 5 of the tutorial right-click the condition you have created.
  2. Click Add action.
  3. Select Send SMS and customize the SMS notification template in the lower part of the Add Action dialog.
  4. Click OK and proceed with step 6 of the tutorial.
Perfect! Works like a charm! Is there a way to suppress the 'Operation succeeded' notification when the rule does run?
It is possible to display suppressed Execution Log if it does not contain any errors or warnings. To do so:
  2. Select the Web Interface type and activate AD Management tab.
  3. Select Only if it contains errors or warnings and click Apply.
I'm trying to implement the script on https://www.adaxes.com/script-repository/changes-in-group-membership-including-changes-made-by-3rd-party-tools-s289.htm. I added my ... is set to run hourly on Domain Admins, and Exchange Admin "group" objects. Thanks
asked Feb 26 by stevehalvorson (110 points)
We are looking for a way to allow AD users to manage group memberships of groups they have been set as Manager for - and would like to know if we can achieve this with Adaxes? We are thinking a easy to use web portal.
asked Apr 17 by Nicolaj Rasmussen (20 points)
We have several Office 365 groups where the someone is an Owner but not a Member, and we'd like to give them the ability through the web interface to give them the ability ... option in the web interface to allow them to add or remove users via a custom task?
asked Nov 1, 2023 by PaulO (20 points)
asked Oct 30, 2023 by Cas (150 points)
Good Morning, Interesting issue, newly created users created in Adaxes don't show AD group membership when viewing in Adaxes but the groups show normally in AD. Users ... idea why users crearted in Adaxes cannot see the groups while other users appear fine?
asked Aug 2, 2023 by curtisa (210 points)
3,377 questions
7,823 comments
545,423 users
