When attempteing to edit the Softerra.Adaxes.Service.exe.Config file there is no listed allowedDomainControllers XML element in my file. According to the instructions below this element should already be in place. Perhaps I am to make that entry into the file?
http://www.adaxes.com/help/?HowDoI.ManageActiveDirectory.ManageDomains.SpecifyDCsForDomain.html
Thanks for your assitance!
by (110 points)
The XML element is present by default in the managedDomainSettings section. If it is currently absent, probably the element was removed manually. You can add it yourself to specify the domain controllers for Adaxes. If you have issues updating the file, please, send it to us (support[at]adaxes.com) and we will update it for you.
Seems like this was a fluke. Not sure, restarting fixed it.
asked Feb 18, 2015 by polley (1.2k points)
asked Jun 26, 2025 by wintec01 (2.6k points)
Hi, the script is only working for groups like A group with multiple values like here is not found: How to change the script to find them as well? I want to find all groups where the extensionAttribute5 is used with the value Permanent.
asked May 27, 2025 by wintec01 (2.6k points)
I was using this and it was working just fine. But now I get this error Method not found: 'Void Azure.Core.TokenRequestContext..ctor(System.String[], System.String, System. ... String, Boolean)'. Stack trace: at <ScriptBlock>, <No file>: line 5
asked Sep 20, 2024 by raphaelgagnon (40 points)
After disable user, not user found or show when try to enable...i follow and try many way yet still not showing.. please help i;m using the ... -not-show-disabled-account https://www.adaxes.com/help/PreventUsersFromViewingTheStructure/#change-top-level-node
asked Oct 23, 2023 by kimtienh (20 points)
