Seems like this was a fluke. Not sure, restarting fixed it.
by (1.2k points)
Hello, When attempteing to edit the Softerra.Adaxes.Service.exe.Config file there is no listed allowedDomainControllers XML element in my file. According ... /help/?HowDoI.ManageActiveDirectory.ManageDomains.SpecifyDCsForDomain.html Thanks for your assitance!
asked Oct 26, 2020 by sgordon213 (110 points)
Error occurs when trying to use SSPR from self-service web interface and from the Windows login screen. Has anyone seen this before? I haven't been able to ... configured exactly how it is laid out here: https://adaxes.com/help/ConfigurePasswordSelfService/
asked Apr 19, 2023 by dhodgin (80 points)
Hello, we have a forest with two trees that hold one domain each. There is a default tree-root trust (transitive, two-way) between the top domains. Since both trees are in ... Sid S-1-5-10 were found". Any help would be appreciated, thank you! Regards HarryNew
asked Oct 8, 2020 by HarryNew (270 points)
Hi, the script is only working for groups like A group with multiple values like here is not found: How to change the script to find them as well? I want to find all groups where the extensionAttribute5 is used with the value Permanent.
asked May 27, 2025 by wintec01 (2.7k points)
