We are currently evaluating Adaxes for our own consulting company and for our customers too.
Our setup include AD On Prem with Azure AD Connect which sync new identities to Azure AD on a schedule.
When we create or update a new account with Adaxes we can rely on Azure AD support but that's kinda partial for what I see.
The best option would be to trigger the Azure AD sync command when we save, to have a more complete scenario.
We followed the related documenation to add a custom action for that purpose, but we end with a priviledge issue.
What is the proper way to have out Adaxes service account allowed to start the sync? This part is not in the documentation we found.
Thanks a lot
by (240 points)
Could you, please, provide all the possible details regarding the workflow you have configured? Please, post here or send us (support@adaxes.com) screenshots.
What exactly do you mean? Do you face any error messages? If so, please, post here or send us screenshots.
by (240 points)
Hello
Sorry, I forgot to close this topic.
Issue I got was not permission related but context related. We had to import the PowerShell Module before running the delta sync.
This is our final configuration:
Import-Module "C:\Program Files\Microsoft Azure AD Sync\Bin\ADSync\ADSync.psd1"
Start-ADSyncSyncCycle -PolicyType Delta
Thank you for the confirmation. You can also use the below script where the $dirsyncServer variable specifies the fully qualified domain name of the server that hosts the AAD Connect tool.
$dirsyncServer = "dirsync.domain.com" # TODO: modify me
Invoke-Command -ComputerName $dirsyncServer -ErrorAction Stop -ScriptBlock {
Hello Forum, in our Adaxes environment we have a lot of security roles (one Security Role per Department). This allows the management of the Department to modify their Users / ... copy it to my newly created Role in powershell? Thanks a lot for your help.
asked Apr 30, 2015 by esoAdxAdmin (650 points)
Hi there, We would like to manage some specific child object, for example msFVE-RecoveryInformation object which is a child of the computer object and contain the bitlocker ... ActiveSync objects to, which are child of user objects. Thanks in advance Stephen
asked Aug 5, 2011 by sroux (800 points)
I'm having trouble with permissions regarding creating a new user. I created a security role for HR and when they try to create a new user and are prompted for a ... Web Interface, because I just tried it with the Superuser account and it is still blank.
asked Oct 9, 2024 by jmatthews (250 points)
Hello, We create home folders using custom command: Service account to perform operations within the domain has: a) domain admin rights b) server admin rights On the ... user as the directory owner, however the user was granted the Take Ownership permission.
asked Mar 15, 2023 by juhota (230 points)
