I'm looking to use AdAxes as a way for new user creation. I'm not familiar with the software, but we have it installed for users, however I cannot seem to find the admin console to do the user creation. Does that need to be installed separately or am I missing something?
by (70 points)
To launch Adaxes Administration Console:
  1. Click Start.
  2. Type Administration Console.
  3. Press Enter.
By the way, it is recommended that only administrators use Administration Console. Other users (e.g. Help Desk) can use Adaxes Web Interface for this purpose. It is a web-based console that can be run in any web browser without installing anything on the users' computers. To launch it:
  1. Click Start.
  2. Type Web Interface.
  3. Click the Web Interface you need.
For information on how to create users via Adaxes, have a look at the following help article: http://www.adaxes.com/help/?HowDoI.Mana ... eUser.html.
The default installation includes Adaxes Administration Console and 3 default Web Interfaces: Web Interface Administrators, for Help Desk an for User Self-Service. If you selected all options by default, you don't need to install anything else.
by (70 points)
I found it in the C:\ProgramFiles... doesn't work with Windows Search.
For troubleshooting purposes, could you provide us with the following details:
  1. What version of Windows is installed on the computer where the Administration Console is installed, including service packs, if any?
  2. Did you sign in using the same credentials as the ones you used during Adaxes installation?
  3. Could you send us a screenshot of what you see after following these steps?
    • Click Start.
    • Type Administration Console.
We need your help, as we are trying to activate the license but we are not able to see that option. Please find the below screenshot for your reference.
asked Aug 24, 2022 by msharma2 (20 points)
I've got a few questions regarding the setup for the web interface and admin console in the DMZ found here. If we don't want the Admin Console accessible outside the network ... users also hit the RODC in the DMZ or would they use the internal DCs? Thanks!
asked May 5, 2020 by scoutcor (180 points)
When using the administration console (not the web console), we would like to be able to customize the fields that are shown on the different tabs of the user properties ... in the web interface but I don't see the same option for the administration console.
asked Jan 27, 2020 by abarker5 (80 points)
Hello adaxes team, im currently getting used to Adaxes after taking the software over from a former colleague (2018.2). What i noticed is that when i open the ... that no Task/Process was executed, simply connecting, editing and saving some custom-commands.
asked Aug 22, 2019 by rhaus (30 points)
Hello, When I want to copy a selection from a report to past it elsewhere (excel,..) it past the a kind of LDAP format path instead the content of the columns. ... web interface but I would like to use the admin console instead. Is that possible? Thanks.
asked Nov 7, 2018 by zemitch (200 points)
