Hi team,
I would like to add an action of having an input of Helpdesk Users, before adding someone to a group.
I tried to create business rule, running "before adding a member to a group" for specific subset of groups.
Then I call a custom command with input. This input needs to be set during config in backend and is never shown to users in portal.
Is this in any way achievable?
I found this old article, but was not very helpful: https://www.adaxes.com/questions/877/custom-scripts-user-input-at-running-time
by (2.7k points)
Unfortunately, there is no possibility to request user input within an automation workflow.
by (2.7k points)
is there a plan to add this feature in future?
Currently, there are no such plans. However, we forwarded your request to the corresponding department for consideration.
asked Feb 13, 2024 by wintec01 (2.7k points)
Hi all, I have a condition during new user creation - Where the corporate email is entered into the email address field, but a custom drop-down for "Mailbox required?" is No. ... screen, and be able to save the result of this choice to a variable? Thanks all,
asked Oct 24, 2024 by dshortall (80 points)
I am using adm-CustomAttributeText2 to capture external email address. And then using the same to create mail enabled exchange account. But I would like ... " -EmailAddressPolicyEnabled $true # Close connection to Exchange Server Remove-PSSession $session
asked Nov 2, 2015 by Brajesh (460 points)
