I have a report scheduled to run weekly with the following delivery options:
There are 3 recipients on this report. For 2 of these recipients, the report is successfully delivered with attachment. For the third recipient (a shared mailbox), the following occurs:
The report is obviously not empty as it is delivered to the other two recipients, and running the report manually returns results.
I also tried changing the delivery options to the following:
But the email is still not delivered to that third recipient.
Any thoughts?
by (230 points)
by (306k points)
A scheduled report is generated separately for each recipient and depends on their permissions in Adaxes. As such, a report can be empty for one recipient, but not the other. To check the report for the recipient in question, you can follow the steps from this help article: https://www.adaxes.com/help/ViewReportAsAnotherUser.
by (230 points)
So it's not possible to deliver that report to a shared mailbox without adding it to a security role in Adaxes?
When I follow those steps to view a report as another user, the recipient in question isn't even selectable.
Edit: It appears I can't even assign that mailbox to a security role.
by (306k points)
Yes, that is correct.
The behavior is by design. Shared mailboxes cannot be trustees in security roles.
Can you clarify the answer as it's a bit confusing? Will there be new major release available this month?
asked Nov 17, 2022 by ColinB (180 points)
Hi, I need to run a schedule task only if a customattribute is not empty. Can I use ConditionIsMet?
asked Oct 7, 2021 by Simone.Vailati (500 points)
asked Oct 5, 2022 by mightycabal (1.2k points)
