Hi all,
I got a script that works, but is kinda finicky:
$memberListProperty = "adm-CustomAttributeTextMultiValue1"
    $records = $Context.TargetObject.GetEx($memberListProperty)
    $records = $null
$guids = @()
for ($i = 0; $i -lt $records.Length; $i++)
    $record = $records[$i]
    $guid = [regex]::Match(($record | Select-String -Pattern "Adaxes\:\/\/\<GUID=.+\>").Matches[0].Value, '(?<=GUID=)[^>]+').Value
    $guids += $guid
$groupname = $context.TargetObject.Get("distinguishedName")
if ($groupname -like "*onmicrosoft*"){
    $servername = "fraisalan.onmicrosoft.com"
} else {
    $servername = "fraisalan.ch"
$members = Get-AdmGroupMember -Identity $groupname -AdaxesService localhost -Server $servername
foreach ($member in $members)
    #Get ObjectGUID of Member
    $binded = $Context.BindToObjectByDN($member)
    [Guid]$nguid = $binded.Get("ObjectGUID")
    #Check if it is in the array
    if ($guids -contains $nguid){
        $Context.LogMessage("$member wurde nicht gelöscht, da es über den custom command zeitlich befristet wurde.","Information")
    } elseif ($member -notlike "*GG_RBA_AD-Bellach*"){
        $Context.LogMessage("$member wurde gelöscht.", "Information")
        Remove-AdmgroupMember -Identity $groupname -Members $member -AdaxesService localhost -Confirm:$false -Server $servername
    } else{
        $Context.LogMessage("$member wurde nicht gelöscht, da es sich um eine Gruppe handelt.","Information")
The script runs for groups, and it should check if a member was added through a custom comand, or manually to the group. If he was added manually, then we will delete him.
My big problem is that the group can exist both on-prem and in the cloud.
The Adaxes Powershell functions (like Get-AdmGroupMember, or Remove-AdmgroupMember) only work with cloud objects if the server name is specified, otherwise they fail.
How can I build it nicer so that I don't have to hardcode the server name?
So basically I want to replace this part:
} else {
Thank you for your help!
Best regards Benjamin
Hello Benjamin,
Specifying the -Server parameter is mandatory in this case. However, you do not need to hardcode domain names in the script. You can use the below code to just obtain it for the target object:
$servername = $Context.GetObjectDomain("%distinguishedName%")
Hi, thank you for your quick answer. It works! You helped me much.
I see the following error when I navigate to the user: The operation couldn't be performed because object '[user] ' couldn't be found on '[local DC]'. We have ... partially manage M365, but I assume its missing some permissions. Any idea what it could be?
asked Dec 15, 2025 by ZoomGhost (370 points)
My role as a developer require a form submission with Adaxes to get JIT (just in time) access to an client environment, I want to need guidance to form submission with the Adaxes PowerShell module.
asked Nov 19, 2020 by spencer.nicol (20 points)
is it possible to register new domain with Active Directory Module Cmdlets ? and is it possible to modify/configure password policies with Active Directory Module Cmdlet ? Thx.
asked Apr 22, 2013 by mmichard (360 points)
I am trying to get a better understanding of how all this works, so forgive me if some of these questions don't make sense. We are trying to remove our final Exchange On ... to the cloud, then I would need to keep our last on-prem exchange server running?
asked Jan 9, 2025 by emeisner (210 points)
I connected my local AD domain as well as my Entra domain in Adaxes, however I am now seeing duplicate user accounts, one under our local AD and the other from ... Connect, and it's confusing determining which user is in which location when making updates.
asked Sep 4, 2024 by aswint (50 points)
