Our helpdesk asked for a solution to easily compare 'member of' details between 2 (or more) users so they can see the differences in group memberships.
by (40 points)
You can use a built-in report, Users' membership in groups. By default, the report is located in container Reports\All Reports\Groups\Membership. For details on how to configure reports in Adaxes Web interface, see https://www.adaxes.com/help/ConfigureReportsInWebInterface.
Would it be best to use the standard Powershell to pull the user's group membership and can that be embedded in a notification email after a user is created? Or is there a variable that will do this that I seem to be missing.
asked Apr 27 by noahphex (40 points)
I find it's a good idea to have backups of a user's group membership when they depart so I'd like to be able to do this.
asked Apr 23 by noahphex (40 points)
I'm trying to implement the script on https://www.adaxes.com/script-repository/changes-in-group-membership-including-changes-made-by-3rd-party-tools-s289.htm. I added my ... is set to run hourly on Domain Admins, and Exchange Admin "group" objects. Thanks
asked Feb 26, 2024 by stevehalvorson (150 points)
We are trying to verify a unique attribute for all users. what we need it to do: 1. Compare "Employee ID" attribute against all users. (to find any duplicates) 2. Needs to ... 4. Email .csv or HTML report to a user. Is this possible with in Adaxes? Tony Babbe
asked Apr 23, 2014 by babbeaw (320 points)
