Receive the following error when trying to access our Exchange properties.
"Could not load file or assembly 'System.Management.Automation, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified."
This has worked up until recently, and I'm not sure where to begin searching for a solution.
Regards.
by (720 points)
Could you post here or send us (support[at]adaxes.com) a screenshot of what you have in folder C:\Windows\Microsoft.NET\assembly\GAC_MSIL\System.Management.Automation on the computer where Adaxes service is installed?
by (720 points)
Above if the file path in question, basically the one directory and inside that the one dll
Thank you for the provided details. Most probably, the issue occurs because the account whose credentials are used to run Softerra Adaxes Service has no read permissions on folder C:\Windows\Microsoft.NET\assembly\GAC_MSIL\System.Management.Automation. To check the account:
  1. Open the Windows Services panel.
  2. Right-click Softerra Adaxes Service and click Properties in the context menu.
  3. Activate the Log On tab.
  4. The username of the account used to run the service will be displayed below.
by (720 points)
Thank you, after some review, a reboot was required on the server. I appreciate the information and will keep it in mind if we every run into this issue again.
Good Afternoon, I'm hoping you can assist - I am a new customer and have just completed our installation. We are currently in the throes of migrating from Exchange ... any additional diagnostics I should be running to track down the problem? Many thanks Steve
asked Jul 6, 2015 by steve82 (50 points)
Hello, I am trying to do as best as I can researching the best and effective way to manage the properties of Office 365 Exchange Properties with Adaxes (Latest Version) ... sure if there is a command or config I missed for adjusting the Distribution Lists.
asked Dec 19, 2023 by Edogstraus00 (590 points)
I am using an account with global admin permissions to o365, so it does not appear to be that as the issue. Adaxes V.2017.2 Trace logs showing the following [11/02/2022 11:24:58] ... at #2e.#Vh.#h8() at #eb.#Wb.#j8() at #2e.#Uh.Execute(#ib command) Any ideas?
asked Nov 2, 2022 by bbrunning (50 points)
Hi, In our system we a hybrid domain with Office365, so on prem AD accounts, O365 mailboxes with an OnPrem exchange for some legacy mailboxes. We have a number of AD accounts ... it's an option in a newer version that's absolutely fine as well. Thanks Gary
asked Feb 27, 2020 by gazoco (490 points)
