Would it be possible to utilize Adaxes' out of the box approval workflow functionality to accomplish the following audit process?
On a periodic basis, each group member's manager is emailed to confirm that their membership in that group is still valid. Ideally a non-response would count as an approval, but a reject would remove the user's group membership. Ultimately the goal is to help with maintaining least privileged principles as access is often granted, but rarely revoked.
by (540 points)
As a solution, you can use the following scenario:
  1. A Scheduled Task will attempt to remove all members from the group.
  2. A Business Rule triggering Before Removing a member from a Group will send an approval request to the user being removed from the group by executing a PowerShell script.
  3. If the user denies the request, they will remain in the group. If the user approves the request, they will be removed from the group.
by (310 points)
Hi yourpp - we have a similar situation and I was wondering if you discovered any other options for your use case?
Regards,
Bernie
by (540 points)
No, not yet. The method proposed by Adaxes isn't trivial because they do not appear to have a native option to specify the affected user's manager for approval, only the requester's manager or owner of the group, etc. Ideally you would be able to use a template for the list of approvers, but cannot at this time, hence the need for a powershell script. To keep it simple, we will probably just use a scheduled task to email the manager with a list of each of their direct reports in the specified group and if they reply, a ticket will be generated in our help desk system and our staff will manually remove the membership.
We would like to be able to, possibly through a script or report, search for attributes that equal specific values and find all rule-based groups that used those rules. An ... and being able to list all rule-based groups that use that in their query set.
asked Oct 5, 2022 by wesmcmillan (20 points)
Hi all I want to create a workflow on the Self Service portal. The choice is the default Join a group or possibly a new action. A normal user should be able to ... by" of the group has the permission (Write membership) as described in the guide. Micael
asked Jan 21, 2019 by ecit (100 points)
I've noticed the following behavior: 1. I have a group (say "group1"). The "owner" (managedby) is set to another group (distribution group) (say "group2"). 2. I ... send a message to "group2" outside of ADAxes, it works fine. Is this expected behavior? Thanks
asked Mar 1, 2012 by BradG (950 points)
Would it be best to use the standard Powershell to pull the user's group membership and can that be embedded in a notification email after a user is created? Or is there a variable that will do this that I seem to be missing.
asked 13 hours ago by noahphex (40 points)
I find it's a good idea to have backups of a user's group membership when they depart so I'd like to be able to do this.
asked 4 days ago by noahphex (40 points)
