Is there a beta available for the current version under development?
If not, then by when is the current development expected to release and what new features would it have?
Thanks,
Jeet.
by (80 points)
Hello Jeet,
2013.2 is scheduled for this Thursday. Only 3 days to wait ;)
Hello Jeet,
New version of Adaxes, Adaxes 2013.2 is now available! You can download it here.
Upgrade Instructions.
Thanks for the reply. I see some nice features being updated in the newer version. Would appreciate if you could confirm, as I am not sure if this release has the feature to customize AD tree visibility. Meaning- allow helpdesk member to only look into certain group of the AD tree and hide rest other groups.
Regards,
Jeet.
Hello Jeet,
Currently, you can do this by adjusting permissions for helpdesk users. You can hide the areas of the AD that you don't want them to be able to browse with the help of Security Roles. Take a look at the following tutorial for information on how to do this: http://www.adaxes.com/tutorials_Delegat ... mUsers.htm. However, keep in mind that if you hide certain objects from users with the help of Security Roles, the users won't be able to see the objects anywhere in Adaxes, neither in the Administration Console, not in the Web Interface.
Also, in the Active Directory Pane of the Web interface, you can build your own custom AD structure. So, you can, for example, disable the Browse button for the Help Desk Web interface to force them use the Active Directory Pane, and customize the Active Directory Pane to show only the objects they need to see. For information on how to implement this, see Configure the Active Directory Pane and step 6 in Disable Specific Web Interface Components.
We have a feature to filter objects in the AD tree of the Web Interface in our TODO list. It will be available in one of the future releases.
We are in the process of updating our Active Directory Domain Controllers to server 2022 and the Domain/Forest function level. Our concern is that we still have Adaxes ... version of Windows server for our DCs and the Domain/Forest function level of 2016?
asked Oct 11, 2023 by sphoeinix (20 points)
Hello, We are glad to inform you that we've released Adaxes 2011.3 beta that includes the Password Self-Service feature. Download links: Adaxes 2011.3 beta x64 ... the announced Scheduled Tasks feature. This feature will be available in the release version.
asked Oct 20, 2011 by Eugene Pavlov (18.0k points)
Question - As we're heading into the final (already) quarter of 2014, I've started to wonder what the next release of ADAXES will look like and specifically what features you all are ... this would be available out of the box. If so, I'll just wait :) Thanks!
asked Oct 8, 2014 by VTPatsFan (610 points)
Hello, after upgrading to 2014.1 the web interface is throwing lots warnings pertaining to groups: Failed to build a list of groups, in which user 'Some.Person@domain.local ... very noisy with these warnings. :) Has anyone else experienced this? Any ideas?
asked Aug 29, 2014 by EgotisticalGiraffe (350 points)
I'm moving from 2013.1 (on Server 2008 R2) to 2014.1 (on Server 2012 R2) and am going from a single server to 2 new servers and will shut down the 2013 ... be updated properly if their target object is moved or renamed. Would another reboot fix this possibly?
asked Aug 26, 2014 by danftasc (440 points)
3,736 questions
550,293 users
