When using the CustomAttributeBoolean properties on a create/update form there is an option to chose either a dropdown or tickbox with options for the True/False values in the drop down.
When using the same attribute on a view form, the value can only be displayed as True/False. I would prefer to show the values I specified for the drop down on the create/update form. Can this be done?
Thanks.
by (390 points)
On July 21, we've released Update 1 to Adaxes 2014, starting from which boolean attributes are displayed as Yes/No on the view form.
How are your boolean properties configured on the edit form? Do you display them as checkboxes or as drop-down lists? In the next minor update to Adaxes 2014.1, we'll make it so that if you've configured a boolean property to be displayed as a drop-down list on the edit form, the options that you've configured for the drop-down list will be used to display the property on the view form. Will that suffice for you?
Thanks, that would be great. Would also be nice if the edit form is configured for checkbox, then a tickbox is also displayed in view!
OK, we'll make it so that if a checkbox is shown for a property on the edit page, something like a checkbox will also be shown on the view page. The only thing is that users won't be able to edit boolean properties by clicking on the checkboxes that are on the view page. To edit the properties, they'll need to go to the edit page anyway.
The checkbox is not selected (False) by default.
asked May 30, 2022 by john.harding (70 points)
Hi, Is it possible to assign friendly names to customattributebooleans? I've searched and tried updating the AttributeFrinedlyNames2 but it still shows the label as "CustomAttributeBoolean" in the form. Thanks
asked Aug 13, 2014 by ColinB (180 points)
asked Dec 12, 2024 by msheppard (840 points)
Users are asking if they can change their name to suit preferred names as opposed to birth names? Is this possible?
asked Oct 14, 2024 by Charlie.Evans (70 points)
we want to pull a simple small data set for a user from a database, store it in an custom attribute and then display it to the users via the we front end EG: ... use a customtextmultivalue but we cant store any formatting in there so the table becomes a mess
asked Apr 5, 2024 by i*windows (300 points)
3,738 questions
8,640 comments
550,340 users
