Does Adaxes have a management pack for SCOM 2007/2012? we are trying to get some monitoring around our servers
by (490 points)
No, we don't have anything like that.
by (490 points)
are their other ways to monitor health? SNMP? WMI Calls? Performance indicator stats?
Actually, yes. Adaxes service installs Performance Counters that allow monitoring the performance-related parameters of Adaxes service using the system Performance Monitor (perfmon.exe). The performance data can also be accessed programmatically, including WMI. For more information, have a look at the following KB article by Microsoft: http://msdn.microsoft.com/en-us/library ... 85%29.aspx.
Microsoft supports decommissioning your last on prem Exchange Server and managing receipients using Windows PowerShell. See: https://learn.microsoft.com/en-us/exchange/manage- ... . Can the Exchange Management Tools be installed safely on an Adaxes Server?
asked Apr 22 by RayBilyk (310 points)
Hello I am looking fro information on managing custom attributes in Adaxes. I would like to create two custom attributes: Self Service Enrollment Stauts Object Type While ... " column above is not a slectable attribute for some reason. Software version:
asked Dec 10, 2025 by apruitt (530 points)
I was wondering if the abilities below are configurable for Domain Admin users in the web portal: Mass password reset Assign different passwords per person, so it's not the same ... to our users, instead of me writing a powershell script to do this. Thank you!
asked Jul 18, 2025 by apruitt (530 points)
What are the minimum security role requirements required for vieiwing management history within the Web GUI. I have granted the following to any authenticated users They are ... permissions should be required for allowing viewing this report in the Web GUI.
asked Feb 10, 2025 by KoleArmstrong (170 points)
asked Sep 18, 2024 by felix (210 points)
