Hello @All,
I'm working on serveral scheduled tasks and business rules.
I have a custom database connection (MySQL) with username and password in the script/scheduled task.
My question:
Is this possible that I define a systemwide variable for the username and password, so I can reuse it in the script/scheduled tasks?
Has anyone a hint about that?
Arne
by (360 points)
Hello Arne,
Unfortunately, there is no possibility to have a global variable that will be used in multiple scripts.
Hi there, we have some custom commands that need the enter-pssession with -sshtransport which is only available in PWSH7. Is it supported to install powershell7 right on the adaxes server? Kind regards, Constantin
asked Mar 3, 2022 by Constey (190 points)
Hello We are currently using IBM Identity Manger, but it's very expensive solution and really an overkill compared to our needs. Wonder if any have experience replacing a "real" IDM system with Adaxes ?
asked Jun 11, 2015 by Boxx.dk (2.6k points)
Im looking for a way to set a global variable that can be called across multiple powershell scripts
asked Jun 11, 2024 by Keonip (180 points)
