I'm trying to understand the best approach to use when developing scripts for Adaxes. In the Management console you can't see the details of an object while coding.
What I'd like to do is figure out the best way to mimic the Context of an object and possibly be able to see its contents and so on. Being able to mimic the %attrib% would be nice as well but I figured that would be replaced after developing something based on a single object.
For Context of a User I'd think a Get-ADMUser might do the trick but its also possible there are additional attributes I don't see.
Thanks in advance for your advice.
by (810 points)
by (810 points)
As I learn in the Mangement Console I've noticed that $Context.LogMessage seems useful for testing and viewing output.
Would this be the recommended way of reviewing script details?
If you need to output specific values (e.g. values of object properties) in your scripts, using the $Context.LogMessage method is the best way. If that is not what you are trying to achieve, please, specify the desired behavior in all the possible details with live examples.
I am introducing Adaxes to more of my IT team ... and this includes those who are in DevOps and want to put everything in a Git repo. I'm not an expert on this ... but I've always managed my scripts manually - keeping copies locally in my file system. Thanks.
asked May 28 by wd.swaters (80 points)
Hello, I have 2 questions. 1. We are in the process of migrating from one AD forest to a new AD Forest. During this migration user accounts will be copied to ... can test in there with out impacting production. Does our existing license cover this? thanks.
asked Nov 1, 2018 by DFassett (710 points)
Now that our adaxes system is in use and active I am trying to figure out how to fix 'bugs' in my scripts and develop new scripts / workflow on a live system without causing ... production? I am curious as to how other customers do this ... Thanks. - Scott W.
asked Aug 11, 2014 by hms.scott (220 points)
Hello, I have a request that is to give an option to run a task that will check a user's litigation hold status in Exchange Online and report back the details for ... users, and return the hold status properties such as hold date and notes? Thank you.
asked Aug 26 by GronTron (390 points)
The csv I am using contains firstname,lastname,fullname,pass I will use fullname for both fullname and log on name and pass for the password.
asked Mar 26 by mightycabal (1.2k points)
