When Setting up a Business rule or custom command to send out an email the option to send for approval is greyed out
NeverMind I overlooked the option in the Business Rule on before Adding Member to Group the action to send for approval
by (60 points)
Hello George,
The Get approval for this action option is used to submit a specific action for approval by specifying approvers right in the action settings. The option is not available for the Send email notification action. The behavior is by design and cannot be changed.
Hi, Our helpdesk staff want to be able to set password options using the web front end but they are greyed out. I've attached a screenshot for the options and current permissions. Is there something I am missing?
asked Jan 24, 2018 by bistromath (860 points)
Hello! I am running a powershell script that takes data and uses that to automatically create New-AdmUser. I want to have that new user send to the approval queue in adaxes, ... user is created, it gets sent to the approval queue. Any help would be amazing!!!
asked Jul 28, 2021 by Monkeyface46 (50 points)
Hello, I'm looking for a way to receive a notification/approval request when a new user is created and the business rule attempts to assign O365 licensing, however ... dependent on the license being assigned. Looking for any suggestions! Thanks so much!
asked Jul 1, 2019 by ryan_breneman (920 points)
Hello Is it possible to only have requests from the Self-Service webpage to be sent for approval? I cans see how you could use a business rule to have all requests to go ... use the Help Desk page we would not need the request to go for approval. Thank you
asked Oct 30, 2014 by CBurn (700 points)
Hi team, I cerated a report containing the creator of a object (email address stored in adaxes custom attribute). Now I want to send out this report to everyone who ... the unique email addresses and use them to send email out. Is that technically possible?
asked Jun 17, 2024 by wintec01 (2.7k points)
