Hi again,
the script here needs a small change
In the last catch area, it has to be $messageEncodingName, otherwise the output will show nothing for default as the value is empty : )
    $messageEncodingName = "UTF-8 (default)"
by (2.6k points)
Thank you for pointing out the issue. We forwarded it to the corresponding department.
We use this date to determin transfers and start dates. Basicaly on this day the Adaxes resets the password. In the report I would like to ... name, first name, last name, employeeID, CustomAttributeboolean1, customattributeboolean2, and customattributedate2.
asked May 17, 2023 by mightycabal (1.2k points)
Dear team, we are using Syslog to store our logging also in an external system. Is it somehow possible to see also this execution log, using Syslog?
asked Oct 27, 2025 by wintec01 (2.6k points)
Hi team, based on Configure Syslog output it says By default, Adaxes uses UDP port 514 to send Syslog messages. Is there any possibilty to change this setting, especially to set TCP?
asked Mar 11, 2025 by wintec01 (2.6k points)
We are trying to set up syslog viewing in Splunk Storm from our Adaxes instance. I have enabled syslog output and put in the appropriate Syslog server information. ... asking for this information in its configuration. Thank you for information you can provide.
asked Sep 22, 2015 by lgibbens (320 points)
Hi team, is there any possibility to see "live" which types of tasks/business rules/scripts/etc are running currently on Adaxes Server? I noticed a CPU of >95% for a while and would like to investigate what is going on and where.
asked Nov 7, 2024 by wintec01 (2.6k points)
